Playlists in MSC mode
Hi! Has anyone found a way to create playlists with the Express in MSC/UMS mode?
I’m using Linux, and would like to create playlists for the Express, but I can only find guides on how to do that with WMP and the Express in MTP mode… :frowning:
Thanks
i would like to know the answer to this qustion as well… can anyone help?
go to Sansa Clip forum and you will find a bunch of ways to do playlist under MSC
I’ve already tried a lot of methods, but they don’t work on the Express.
In this player the playlists are stored somewhere (and somehow) inside the database. Creating a .pla file, whichever method one uses, won’t work on the Express.
They won’t even show up in the playlist menu.
