Hi, since I finally clear all my doubts I’ve been trying to put playlists on my device but I can’t. If someone can put playlists on the Connect explain if I need some program: MediaMonkey, WM10 or just make it on explorer and drop it. Thanks
Any music manager which can sync in MTP should be able to put a playlist (created by that music manager) on the Connect. I do it with MediaMonkey all the time.
Can you post how you make a playlist and how sinc it with MediaMonkey?
On the left-side of MediaMonkey, right click “Playlists” and select “New Playlist”.
Name the playlist.
On the left-side of MM, click on Library, select and drag songs to your playlist now shown under “Playlists”.
When done, right-click on your playlist, select “Send to…”, and then select "Sansa Connect (Synchronize) ".
Thanks PromisedPlanet, help me a lot. Also if someone has another procedure to make playlists post it to compare
Creating a playlist with WMP10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/makeplaylist.mspx
