I’ve attempted to create a playlist on wmp 11 and sync it with the sansa. It finished syncing but when i check the sansa its not in the playlist section. Is there something im doing wrong or am i supose to sync another way?
Message Edited by blacksyth on 08-21-2009 05:20 AM
I use MediaMonkey and haven’t had a problem syncing playlists to my Connect.
I’m not sure about WMP11, but MediaMonkey syncs the songs in the playlists first, then the playlists themselves. So if you disconnect your Sansa before the playlist files have copied, you could see what you’re seeing.
