I go in and sync the files through windows media player, with the playlists created in windows media player, and they lump all the songs together in one list, with no playlists showing up on the playlist tab on the mp3 player itself.
Okay. This has got to be the least user-friendly mp3 player ive ever seen, but here’s how you do it.
MSC mode. Open the mp3 player using explorer, open the audible folder in there. Drag in whatever folders full of music you want, to differentiate the different playlists.
Open your music player of choice. open a new playlist in it. click open one of the folders you dragged into “audible” to designate playlists, and highlight all the mp3s. drag them into the “playlist” for the computer music player. SAVE that playlist in the default format INTO the same folder you dragged the mp3’s from, on the mp3 player itself.
This, in fact, works. Maybe theres a simpler way, but it sure as hell isnt obvious. Not that this is hard, its just a lot of steps.
Hopefully this info will save someone else the headache i just endured.
Try following these steps in the following How-To Videos for an easier way of adding a playlist.
[How to Add a Playlist in WMP10
](http://mp3support.sandisk.com/wmp10/wmp10playlist.wmv)[
How to Add a Playlist in WMP11
](http://mp3support.sandisk.com/wmp11/wmp11playlist.wmv)
Here is a link to the rest of the videos.
it works on sansa m230…
use the program Playlist Creator 3
set mp3 sansa usb in MSC mode and
look this…
video
Luck ![]()
I come to find that it has to be in auto detect mode for a playlist to transfer properly, whatever that means.
Hopefully someone who has influence on the design of this unit’s firmware/software, etc. will read this thread.
Please inform whomever that may be that there is little logic behind the layout and design of this player.
It’s a great piece of technology and is quite ruined by a few minor shortcuts and/or flaws in the method upon which
a)playlists are created
b)the file system is managed by the player
c)the user interface for pc clients provided
d)the user interface for the sansa player internally.
Some of thses things include:
playlists MUST be bound to not only a subfolder (no root support unless manual for Go List only) but MUST contain ALL songs in their entirety.
-drawback :What if I have a folder in Music called “Jazz” but I want my playlist only to contain 12 of the 102 Jazz mp3 files that are in there… I cannot do this.
-drawback :A user cannot simply go down a list of mp3 files regardless of where they reside and “tag” them to a playlist. (PC SIDE and NOT Go List)
for example, if I had 3 folders “Jazz” “Metal” and “British Rock” and then in the root had 200 mp3 files, let’s say I want to construct a playlist on my pc
that would have SOME tracks from “Jazz” and only a select few from “Metal” and a handful from “British Rock” and then about half of the root mp3 files…
this cannot be done.
-drawback:A user cannot call the playlist whatever they wish and have it contain any assortment of non-contiguous mp3 files. Even if they are in one folder.
The playlist MUST match the foldername. My Mix.pla/plp containing all mp3 files from Jazz cannot happen.
Also why is the extension of contructed (via Sansa Playlist Creator by Tu Wein) .pla whereas when it creates the Go List it’s extension is plp.
Why aren’t they all the same and what is the difference?
Use of menus does not allow direct forward and backward navigation.
-drawback: There are menu items that you can get to but you cannot back out of them.
-drawback: There is no “Now playing” feature such as on the Creative Labs Zen:Vision M which will drop any currently viewed menu item and go directly to the playing song/video
-drawback: You cannot backtrack to save time or see the screen beforehand. Some menus do not back out the way you got in. (Such as a back button on a browser.)
There are a few more items but I think this gets the point across.
The player’s capabilities such as 8Gb of solid state storage, relatively fast processor and extremely low voltage consumption for extended use on one charge in addition to an incredibly small size
yet while maintaining a useable screen for videos, makes this a great player and an attractive buy, but ownership and use will serve to discredit all of those hard accomplished breakthroughs
in consumer technology.
Just a thought.
BTW I understand that MP10 does this all very easilly but I don’t have it nor do I want to endure the schema changes in order to upgrade to it.
As well, it requires SP2 and I do not wish to run SP2 on my system because then I will no longer have the ability to join domains.
My laptop MUST be able to join domains for me to keep my job.
I think what I will have to do is stage a workstation that has all the MS ■■■■ and latest everything patch wise
seeing as how Vista and SP2XP are being shoved down my throat. It will be stricktly as a compatability system so I can do playlists on my sansa.
(As well as a slew of other things that I have been prejudiced from participating in because I am refusing to adopt all updates blindly)
Also after watching that video I’d like to see the file structure. I am willing to bet there’s a new folder called “newplaylist” with those 3 songs in it.
Maybe I am wrong but I’d be plenty shocked if that weren’t the case.
Message Edited by playlistsblow on 03-16-2008 09:47 PM
Try this. It works everytime using Windows XP and Windows Media Player 10, which the m200 series were designed for.
Part A: Prepare the Player and Windows Media Player
Part B: Load your Playlist on the m250
You should now have a playlist on your m200 that works. To update this playlist or add additional playlist(s), go through Step B above. You should need to repeat Step A if your device locks up or starts doing weird things. Sansa support recommends formatting the device occasionally to remove fragments, residual data, etc… They also recommend formatting the device in MSC mode before starting on Step A above.
