Hey all,
first of all I want to apologize if my English is some kind of weird. I’m from Germany and my English isn’t very good at all!
Now to my problems:
For two days now I’m trying to get a playlist on my Sansa Express. It has the firmware version 01.01.01A.
I tried the SanDisk Updater but after the installation nothing happends and when I try to open the program manually it just gives me an error.
Furthermore I dont have the USB Option on my Sansa Express and I cant switch from MSC and MTC (or whatever they are called like). So far I
can see them on my PC as an usual USB Devices (I can store music etc. by drag&drop on them).
You may ask why I am trying to update my firmware. It is because that stupid playlists wont show up on the Mp3 Player. I tried to sync them with WMP11 and I also tried it with Winamp. I saved .pla and .plp files, as well as .mpu files on the player, but they just dont show up then I go to Music -> Playlists. All I can see is the “To-Go-List”…
As I said the firmware updater didn’t work. Im from Germany and I think that I am using an European device… So I need some European files for the manuel update and I hope the playlists will work then! If not, im **** upset ![]()
greetings from Daniel
