Is there a limit to the number of songs that can be in any given playlist for the ClipZip or Clip +? I notice the Go List has a 200 song limit…Does the same hold true for playlists I create on my device?
Thanks!
Thanks!
I believe there’s a 1000 track limit on playlists, but I could be remembering incorrectly.
i thought user created playlists are limited to 400 tracks.
Just for fun, I quickly threw together an m3u playlist of 1099 tracks. The Zip sems to be playing it fine, although without the count reference on the screen (25/1099 for instance), it’s hard to say if all the tracks in the playlist are being seen by it or not.
I suppose I could play it from start to finish and see if any are missing . . . it would only take 75 hours, 44 minutes and 23 seconds. ![]()
Tapeworm! I’m surprised and shocked that you don’t know this! All you have to do is press the >> button 1099 times.
@mags1230 wrote:
Yeah, I could do that . . . but I might end up like this:
Thank you for checking this out!
I’m unable to get any playlists whatsoever to appear on my ClipZip (m3u format)
No problems whatsoever on my Clip+
What gives?
What gives?
I don’t know. I put them on my Zip the exact same way I do on my Clip+ and have no problems. How are you doing it?
I have discovered it’s because I have my device in MSC mode… and the clip zip doesn’t recognized playlists saved in MSC mode
I have installed the much older 01.01.12 firmware (which doesn’t have this problem) until SanDisk releases a firmware that fixes it.
http://mp3support.sandisk.com/firmware/clipzip/clipzip01.01.12.zip
Balderdash. I have used nothing but MSC mode with all my players (including the Zip with the latest firmware update) and have no problems creating .m3u playlists that work.
