Pen drive not able to copy large file above 3 gb
Purchased new usb drive 3.2 version OTG type C from Flipkart. I tried to copy large file above 5 gb but not able to copy showing error of large file cant copy . Then I format pendrive now it is copying but space reduced to 57 gb which is large before format now what to do ?
Hi @Ravi812
Please check the below link format the drive provided instructions.
Title: Format a USB Flash, Memory Card or External Drive with the Original File System on Windows and macOS
Link: Format a USB Flash, Memory Card or External Drive with the Original File System on Windows and macOS
If your USB drive is formatted as FAT32, it can’t handle files bigger than 4 GB. You can reformat the drive to change it. Save any important files from the drive before reformatting, as this will erase everything.
Reformat the USB Drive -
  • On Windows:
    • Right-click the USB drive in File Explorer and choose Format.
    • Select exFAT or NTFS as the file system, then click Start.
  • On macOS:
    • Open Disk Utility, select your USB drive, and click Erase.
    • Choose exFAT or Mac OS Extended (Journaled), then click Erase.
After formatting, make sure the drive shows its full size (like around 64 GB for a 64 GB drive). If the space is still showing as reduced or you have issues copying files, the drive might be faulty. You should contact Flipkart for a replacement or return.
  1. Reformat the Drive:
  • Right-click on the USB drive in “This PC” and select “Format.”
  • Choose exFAT or NTFS to allow large files (over 4 GB) and do a quick format.
  1. Use disk management tools to find and remove any hidden partitions taking up space.
  2. Use Diskpart (if needed):
  • Open Command Prompt as an admin and type diskpart.
  • Select your USB drive by typing select disk X (replace X with the drive number) and then type clean to remove partitions.
  • Create a new partition with create partition primary and format it with format fs=exfat or format fs=ntfs.
  1. Check for Drive Errors:
  • After formatting, check for errors by right-clicking the drive, going to “Properties,” then the “Tools” tab, and clicking “Check.”
format fs=ntfs is for harddrives not USB drives.
Yes, you are right.
Yes, you are right. Buying an essay from ukwritings.com/buy-essay was a great experience. The writer demonstrated expertise in the subject and delivered a paper that was insightful and well-structured. The quality of work was excellent, and the essay was delivered ahead of the deadline. The customer service team was also very responsive and helpful. I would recommend this service to anyone looking for professional academic support.
