not enough space / reformat player
I just deleted all the songs on my m240.  When I went to add new songs, it’s telling me there is not enough space.  I checked the properties through windows explorer and it’s is telling me that it has no free space.  Yet when I look where the songs used to be, it is empty.  I am guessing I need to reformat the player, but I’m not sure how to do that.
Any help would be great!
Thanks,
Mark
Put the player in MSC mode. You can do this by turning on the hold
switch before connecting to computer. Also can be set in the settings,
USB of the player menu.Turn on the hold switch and plug the m250 into
your computer. Find the Sansa removable device under My Computer.
Right click on the Sansa icon and select Fat32 from the list. Then
select format.
Click here for helpful User Guide and Videos
