When connecting my SanDisc Clip Sport Go to any computer, it doesn’t give me the option to add or remove files anymore. The Clip Sport Go will appear in the devices list for around 2-3 seconds before it’s name disappears and is replaced with ‘USB device’.
When this happens the Clip Sport Go will change from the ‘transferring’ status to the ‘charging’ status as though it is charging from a wall socket.
This makes it impossible to add or remove anything. The device will charge successfully.
Originally I had assumed there was a problem with my cable but I have tested it on my old Clip Zip and the cable works fine. I’ve tried other cables that work fine transferring data with the Clip Zip and they don’t work on the Clip Sport Go. My worry is that this may be a hardware issue with the USB port on the Clip Sport Go.
Has anyone had this sort of issue before?
