Nikon DX Memory Card Problem
I have a Nikon DX camera. What is the right size and type memory card to use with the camera? I bought a SanDisk Extreme Pro SDXC UHS-1 Card 64 gb and after I reformat it gives me a reading that the disk is full (it isn’t). How can I either fix that or what is the best type and size card to use with the Nikon DX (old camera).
Thank you
Hi @sherlern,
I would suggest that you format the card with a compatible file system format. For SDXC cards larger than 32GB, it’s recommended to use the exFAT file system. Some older devices might not support exFAT, so you may need to format it to FAT32, though this format has limitations on file size.
