Ok. so I bought a cruzer orbit 32gb yesterday.
I pluged it into my computer and for the first time it was perfect.
I put in all the files I need onto the drive then have it unpluged.
plugged it back into the computer at night and the drive cant be regonized for 3 mins.
3 mins later the drive shows up and its empty. Not 0 / 32gb empty…but 0mb / 0 mb kind of empty.
so I did some researh…went to device manager, have the orbit’s driver uninstalled.
unplug then plug it back in, the flash drive immediately started to work again…
I thought…wooo…I fixed it.
but nope!!
The next unplug&plug did the same thing again. Which means I have to uninstall the driver everytime if I want to use it.
At first I thought it was my computer thats causing it. I have 3 other usbs laying around and none of them caused any problem.
hmm…so I thought…may be its the Orbit’s problem? brought it back to the store have it exchanged for a new one.
and the same thing happens…sigh…
I tried it on another computer the orbit was working perfectly fine…
so … basically this is happeneing only on my computer with only curzer orbit…
I am running
CPU: i7 920,
Ram:12GB
OS: Win7 64bit
HELP!!!
