MyBook clash with OneDrive
I have two MyBook external drives
Had to get the second because OneDrive ate up all of the space in the first drive
Long story… OneDrive ran amuck and ate up all of the available disc space on my PC,
and a standard WD 1 TB drive and MyBook.
I managed to stop it with just 40 GB space left on my PC and deleted a whole bunch
of files to make space.
I’ve not added anything to the first MyBook in about 1 1/2 years… however, it keeps
filling up.
One time, I went through folders and found dozens upon dozens of replications of
files and folders - inside folders… deleted all that i could find.
I just installed space sniffer and ran it on the mybook …
the largest use of space in MyBook is 424.9GB for File History???
how and where do I find this “file history” and what do i do with it?
thank you kindly for your help
Karen
Hi kstavert,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
