Backups frozen after running out of space
Hello, I have a MyBook external running SmartWare (v2.4.16 on Win 10 64) for backups but it hasn’t done anything since it ran out of space.
When I noticed it had run out of space it initially had me confused when I deliberately bought a drive with more space than my PC has. I found in the settings that it had defaulted to keeping 5 versions of file history and reduced it to the minimum of one. I expected it would gradually free up space but instead it seems to have frozen at that point. I’ve poked around in it a bit and not found any new files since that time. I don’t see any way in the app to purge history, so I don’t see any choice other than deleting everything and starting over from scratch. What else can I do?
Thanks
Hi gj42,
You should try to re-install the WD Smartware and then try to create the backup. If you still face the same issue then you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
Thanks, I’ll give it a try.
