Today I don’t understand why my usb is faulty
I just turned on my laptop and opened Windows Explorer and didn’t see the partition of the usb, so I opened disk management, it said No Media in Disk 1
help me please! ![]()
Try running a CHKDSK F: /F command for the drive. Shutting a pc down when something is writing to a removable drive can cause it to get screwed up.
okay, i will try
hmmm Ok, try shutting the pc down, remove the USB drive, and see if you can try it in a different pc. Another option might be to boot your pc in Xenon , plug your USB drive in and see if it’s recognized then.
I tried it on another PC but it didn’t work, so I reinstalled the firmware for this and it worked
Thanks for helping me!
Excellent!! Thanks for the update. Have a Happy New Year.
I have the same issue No Media I have try with another pc
try re-flash your usb
I believe that the driver is responsible for communicating between your computer and the USB drive. If the USB driver is outdated or corrupted, it can cause problems with detecting the USB drive. To update the USB driver, open Device Manager and expand the “Disk drives” category. Right-click on the USB drive and select “Update driver”.
No worries, this is actually a common issue with USB drives. The “No Media” message in Disk Management usually means that Windows is detecting the USB port itself but not the actual storage inside the USB drive. This guide provides some basic solutions for the “flash drive no media” error. If all else fails, your drive might be corrupted. It’s best to contact a professional repair service.
Even though the drive itself is physically recognised, if your SanDisk Cruzer Fit 16GB USB drive displays a “No Media” error, it often indicates that your computer is unable to recognise the USB drive’s storage space. Hardware failure, firmware problems, or logical corruption may be the cause of this. I suggest you use the professional solution that helps you in this situation. I tried the BLR Data Recovery Tool to recover my USB data.
Try Basic USB Port Troubleshooting
- Reconnect the drive in a different USB port.
- Try it on another computer to rule out system-specific issues.
If this method also does not help, then you need professional software for this problem.
I successfully fixed this issue by reflashing the firmware for it. I really appreciate you all for providing the repair solution for me, but I had already successfully fixed the problem a long time ago ![]()
Next time you encounter the “Removable No Media” or “USB No Media” error, you can try the following steps:
Check the connection: Restart your PC, test the device on another PC, use a different USB port or cable, or connect the USB device directly to a port on the motherboard.
Use third-party disk software to see if it can be recognized.
Update or reinstall the USB driver.
Run the Windows Hardware and Devices Troubleshooter to detect and resolve common hardware-related issues.
- Go to Settings > Update & Security > Troubleshoot > Hardware and Devices.
- Click the ‘Run the troubleshooter’ button
Related: How to Fix Removable/USB No Media in Disk Management Error
