My sd card having important videos and images got corrupted now i want to fix problem
My sd card got corrupted all my important videos and photos got vanished what to do. Pls guide
Hi @Romandghising
(Get Support for Your SSDs and Flash Products | Sandisk)
(Contact Support | Sandisk)
If your SD card suddenly went corrupt, stop using it right away to avoid overwriting anything. Try checking it on another device, running a basic error check, and copying any visible files first. For a clearer walkthrough, follow the step-by-step fixes in this tutorial video—it shows exactly what to do. https://www.youtube.com/watch?v=Fl_Mc-zIjh8
First, open Disk Management to check the current status of the SD card.
1). If the drive letter is missing, the SD card may not appear in File Explorer even though Windows detects it. In Disk Management, right-click the SD card partition and choose “Change Drive Letter and Paths.” Then click “Add” and assign an available drive letter. After confirming, the SD card should appear in File Explorer and become accessible again.
2). Reinstall the SD card drivers if the card is not properly detected. Open Device Manager, expand Disk drives or Universal Serial Bus controllers, and locate your SD card or card reader device. Right-click it and choose Uninstall device, then remove and reconnect the SD card or restart the computer. Windows will automatically reinstall the correct driver and attempt to detect the SD card again.
3). Use Windows Error Checking to repair file system issues. In File Explorer, right-click the SD card and choose Properties → Tools → Check under the Error Checking section. Windows will scan the SD card for file system errors and attempt to repair them automatically. This method is useful for fixing minor corruption that prevents the SD card from opening normally.
4). Run the CHKDSK command to repair memory card errors. Open Command Prompt as Administrator and type a command such as:
chkdsk X: /f /r
Replace X with the drive letter of your SD card (such as D or E). The /f parameter fixes logical file system errors, while /r scans for bad sectors and recovers readable data. The process may take some time depending on the size and condition of the SD card.
If the CHKDSK utility reports that “CHKDSK is not available for RAW drives,” it means the SD card’s file system has become RAW, which usually indicates severe corruption or formatting issues. In this situation, Windows cannot repair the file system directly. The recommended approach is to use professional data recovery software to scan the RAW SD card and recover important files first. After recovering the data, you can reformat the SD card to a supported file system such as FAT32, NTFS, or exFAT. Reformatting will restore the card to normal use. Read also - Ultimate Guide to Fix Corrupted SD Card and Recover Data
If your SD card appears corrupted and your photos and videos are missing, do not use the card further. Continuing to record or copy files may overwrite the lost data and reduce recovery chances.
First, remove the SD card and connect it to a computer using a reliable card reader. Check if the card is detected in Disk Management or Finder. If it appears, but files are inaccessible, run a photo recovery tool such as Stellar Photo Recovery to scan the card. The software can search for recoverable photos and videos even from corrupted cards. After scanning, preview the files and save the recovered data to a different drive, not the same SD card.
Read: SD Card Recovery – Recover Deleted Photos & Videos (2026 Edition)
Try Immediate Recovery Steps:
Stop Using the Card: This is the most important step. Do not take new photos or save new files, as this will overwrite the “invisible” data you’re trying to save.
Try a Different Reader: Sometimes the issue is a faulty USB port or card reader rather than the card itself.
Use Data Recovery Software: Tools like Easeus data recovery (free) can scan the card’s sectors to find and reconstruct your lost videos and photos.
Run CHKDSK (Windows): If your computer recognizes the drive letter (e.g., E:), you can try to repair the file system by typing chkdsk E: /f into the Command Prompt.
This is not new here. Corrupt SD card can make the data lost and make it inaccessible for anyone. First try to mount the SD card on your computer, look for hidden files and see if you can find those. Alos, dont try to format the card as this may make recovery difficult.
Next, you may require a recovery tool like Stellar Photo Recovery. This is a specialized tool for photos and videos, which can recover from any corrupt/formatted SD card. This tool will help you find all your lost photos and videos easily as it main thing is SD card Recovery.
First, stop using the SD card immediately to avoid overwriting anything. Then try these steps:
  • Insert it into a computer using a card reader (not your phone).
  • Run recovery software like Recuva, Disk Drill, or PhotoRec—these can often restore deleted or corrupted files.
  • If the card isn’t recognized, try assigning a drive letter in Disk Management (Windows).
  • Avoid formatting unless recovery tools specifically require it.
If the data is extremely important, you might want to consider a professional data recovery service as a last option.
Hope you’re able to get your files back
If the photos and videos disappeared after the card became corrupted, I’d avoid using it any further until you’ve tried recovery. CHKDSK can sometimes make things worse if the file system is badly damaged.
First create an image of the card if possible, then try a recovery tool that can scan a corrupted file system instead of just deleted files.
If the card still shows the correct capacity in disk management, there’s a decent chance the data is still there.
