ohh did it work ?
if your talking to me, you welcome. and idk lol.
SouljaBoy wrote:
ohh did it work ?
Grow up! If you want to talk to yourself, please do it somewhere else. If you are replying to a particular post, then please âquoteâ that post so others will know who and what you are respondinig to. Thereâs a Quote button in the upper right corner of the message composition page that will insert it for you.
Thank You, Thank You. It worked!
Fantastic. I just sat down to research purchasing a new product and Googled âmy sanza fuze wonât turn onâ on a wim. I am thrilled :smileyvery-happy: it is working again! 15 seconds is a long timeâŠwhoda thunk it. Thanks a bunch.
during afterschool program mmy fuze went out too. but i found a solution.hold the power swith and press home. after you do that the screen will show ârefreshing your memoryâ
Thank you so much. It works!
NOTHING IS WORKING, HELP!!!:robotmad:
that happened to me last night, have you figured it out yet?
thank you⊠i was just about to give up then i read yours and tried turning mine one again. and it worked ![]()
i agree i need help also. mine did the same and never turned on! i was so upset and i lost all of my music. ive tyed charging, resetting, everything
OMG thank you!! my bf nd i switchd mp3 nd it turnd off!Q i thot i broke it!!!
thanks this was very helpful just bought it 7 days ago antd it did the same thing. you post was very helpful thanks.
hola mi sansa es de 4gb fuze y no funciona pornada del mundolo conecto ala compu y no funcionaÂ
ni si quiera carga  a un detallito cren que pueda funcionar con un cable usb de un ipod pues la entrada es la mismaÂ
nose si puedad resolverme eso y cuanto cuesta el cable para el
hola quien me puede alludar con mi sansa dandome condÂżsejos para  aserlo funcionar lo que pasa es que lo deje se usasr por un año  y despues cuando lo quiero usar no funciona ni siquiera carga o mas bien no lo reconoce la computadoraÂ
y tambien si me podan deir como resetearlo por que no se
wat page did you logged on??
or how did you made it work?
What exactly is the unit doing, CarlaF?
Good morning everyone.
Thanks for all the reset hints in this thread. I have a SANSA fuze 8GB that really stays off⊠I tried all the suggestions (keeping power up fo 10 seconds, 15 seconds, middle button pressed, middle AND play button pressed during those seconds) but no luck. The thing wonât budge.
The ONLY two things that seems to happen is when I plug it in a computer with the USB port to my Windows 7 PC.
The new USB devide wizard starts is followed by the âDevice Driver was not succesfully installedâ popup on the bottom right of the PC screen.
If keep the USB plugged in AND I do the 15 seconds power slided up, Windows tells me " you need to format this disk". If I click on the âformat diskâ button, the format window comes up with only 4.03 MB to format. If I decide to proceed, the formating will fail.
So I guess I am stuck⊠any ideas anyone?
Nic
Youâre doing too many things at the same time.
With the unit OFF, slide the power button DOWN into Hold position. It will click and reveal an orange dot.
Connect the USB to the computer, open Windows Explorer (Computer), hold the << and connect the USB to the Fuze. What happens?
I got a new Fuse 2G. Got to where plugging it in starts media player. I give it a name in media player but eveytime I plug it in it asks me again. Canât seem to download songs to it. Also, main concern here and why Iâm on this thread, it wonât turn on when disconnected from computer. I get the blue ring when plugged into computer but when disconnected I canât get anything to happen. Tried the 30 second reset. HELP!
