My Power button is stuck inside my player? HELP!
I dropped my Sansa clip on the floor. Now I can’t press the power button. I can’t cut my device on or off.
HELP?
I got the Same problem. very frustrating some one heeeelllllppppppp
Taking it apart and seeing if you can fix it or buying a new one are about your only options.
There are disassembly tips and pictures over at the anythingbutipod forums, but once you get in there, whether it will be something you can correct is iffy.
Does anyone know how to bypassthe power button…
