Hi i have a SanDisk micro SD with files and photos and I deleted them but I plug it back into my window laptop and looked on the the micro SD and there they were the same files and photos I just deleted I have tried format and the files and photos are still on there and I don’t know what to do next?
Hi @Strikey
It could be due to the card being write-protected, corrupted, or any problem with its file system. Check the lock switch is not in the locked position. Else format the card.
You can easily remove the write-protection from the SD card using the Diskpart command, Windows Registry Editor or Group Policy. Check this article remove Write Protection from SD Card.
Thanks for solution
Strikey, your SD card may be experiencing corruption or write protection, which can prevent successful deletion or formatting. First things first, check the adapter for your micro SD card (if you’re using one) and make sure the switch is not in the ‘Lock’ position. Then, insert the SD card into another device and try deleting the files from there. Check out this blog post to learn more about the ‘files not deleting from Micro SD card’ issue.
BTW, consider using a dedicated tool like the SD Card Formatter from the SD Association. Sometimes these tools are more effective than the built-in OS utilities.
The issue with your SD card might be due to write protection, corruption, or file system problems. First, check the lock switch on the card to ensure it’s unlocked. If it is locked, change it. If the card still doesn’t work, consider formatting it.
To remove write protection, you can use:
- You can use Command Prompt to access Diskpart and remove write protection.
- You can edit the registry settings to disable write protection.
- You can also use Group Policy if your Windows version supports it.
