My 16GB SanDisk Cruzer Facet Flash Drive -HELP
When running diskpart, I got this status:
Current Read-only State : Yes
Read-only : No
How do I fix this flash drive? It’s corrupted, won’t let me format it, and I can’t delete any files.
DISKPART> select disk 2
Disk 2 is now the selected disk.
DISKPART> attributes disk
Read-only : No
Boot Disk : No
Pagefile Disk : No
Hibernation File Disk : No
Crashdump Disk : No
Clustered Disk : No
DISKPART> clean
DiskPart has encountered an error: The request could not be performed because of an I/O device error.
See the System Event Log for more information.
DISKPART> detail disk
SanDisk Cruzer Facet USB Device
Disk ID: 43F951DC
Type : USB
Status : Online
Path : 0
Target : 0
LUN ID : 0
Location Path : UNAVAILABLE
Read-only : No
Boot Disk : No
Pagefile Disk : No
Crashdump Disk : No
Clustered Disk : No
Volume ### Ltr Label Fs Type Size Status Info
Volume 5 E HIREN NTFS Removable 14 GB Healthy
The FDIE app has detected the flash drive’s status:
Volume: E:
Controller: SanDisk
Possible Memory Chip(s): Not available
VID: 0781
PID: 5576
Manufacturer: SanDisk
Product: Cruzer Facet
Query Vendor ID: SanDisk
Query Product ID: Cruzer Facet
Query Product Revision: 1.26
Physical Disk Capacity: 16008609792 Bytes
Windows Disk Capacity: 16008577024 Bytes
Internal Tags: 3Y4F-8CB4
File System: NTFS
Relative Offset: 31 KB
USB Version: 2.00
Declared Power: 200 mA
ContMeas ID: 650F-01-00
Microsoft Windows 10 x64 Build 19045
My question is: can anyone here explain what’s going on, share a solution, or recommend an app I can use to get this flash drive back to normal?
Thanks a lot, sir…
( Get Support for Your SSDs and Flash Products | Sandisk )
Try this one.
Thanks for the update, Mr. SBrown. An I/O device error usually means Windows is having trouble communicating with the flash drive’s hardware.
Could you try these quick steps to see if we can get it working?
  1. Try plugging it into a different USB port (or another PC if available). => did not work.
  2. Run a disk check: Open Command Prompt as admin, type chkdsk X: /f /r (replace X with the flash drive letter), and press Enter. => did not work.
  3. If Windows asks to format it, we might need to use a tool like Rufus to reset the drive, or Recuva if you need to save the data first. => did not work.
Let me know if any of those steps work! Any idea, sir…?
I believe that your SanDisk flash drive has permanently failed. It is a physical hardware failure rather than a software glitch. The failure of the clean command with an “I/O device error” confirms that the hardware is no longer accepting any write commands.
Since the drive is readable, you need to immediately copy all important files off the drive onto your computer. Also read: How to Fix I/O Device Error on Windows? (9 Fixes)
