Hi folks, I recently purchased a SanDisk Ultra 80MBs MicroSD Memory Card - 128GB to put music on to use in my phone. I’ve tried transferring the music on my laptop with two different adapters, a USB cable and a microSD adaptor. Every folder transfers but when I check the SD contents a majority of the music folders are empty even though they have songs in on the PC. I then used iSyncr which transfers to the SD while it’s in the phone and the same thinghappened. I’m a real novice at this but I have done it before with smaller SD’s with no problem. I used H2testwand this is the results.
Verifying 4673Mbyte
4.53 min
15.9 Mbyte/s
Warning only 4673 of 127968 MBytes tested.
Read speed 15.9 MByte/s
I’ve scanned/chkdsk/quick formatted/fully formatted the card but the same thing happens.
Have I a dud card or am I doing something wrong??
Remember folks I’m a beginner novice ![]()
