Micro Sd wont formar
Help please. I have a 1tb micro sd that displays as “raw” and when inserted, prompts a format. When i try formatting in windows i get a message “windows could not succefully format” or similar. I have tried the below
DISKPART - clean, format, remove write lock.
Disk genius- erase disk, format, delete partition
None of these actions change the scenario. Any suggestions?
Hi @Limiterbash,
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this.
(Contact Support | SanDisk)
There can be many reasons for SD cards won’t format errors. The memory card might be corrupted. Its file system may have turned raw, or your computer doesn’t recognize the SD card at all. If your SD card is connected and visible on your computer then you can format it in many other ways. Check out this article to know the fixes on SD Card won’t format.
Have you turned off the write protection switch on your SD card? If you receive the error message “Windows was unable to complete the formatting,” it’s advisable to first remove the write protection from the SD card.
Here is how to remove write protection from SD card using Diskpart:
  • Put your SD card into your computer’s card reader.
  • Press Win + R, type cmd, then press Enter.
  • Right-click on Command Prompt and choose “Run as administrator.”
  • Type diskpart and press Enter.
  • Type list disk and press Enter. Find your SD card in the list (it’s usually labeled by size).
  • Type select disk X (replace X with the number of your SD card) and press Enter.
  • Type attributes disk clear readonly and press Enter.
After removing the write protection, please try to format the SD card using CMD again. This blog gives more solutions about Windows cannot format SD card.
There are a lot of discussions on forums about problems with formatting SD cards. Some users have recommended trying the Bitraser tool. I haven’t used it myself, so if you decide to try a third-party tool for formatting, make sure to do your research first.
Many reasons can cause the “Windows was unable to complete the format” error, such as:
1. The device contains the file system error: When a storage device displays as RAW or contains an unsupported file system such as Linux Ext2/3/4, Windows won’t be able to directly format the device by using File Explorer or Disk Management. To fix the ‘can’t format SD card’ error, you maybe need a third-party formatting tool for help, or run the Diskpart command --also your case
2. Presence of bad sectors
3. Virus or malware infection
4.The device is locked or write-protected by third-party software
5. Physical damage
In your case, you can try the Diskpart command; check out steps:
Step 1. Right-click on the Windows icon, type the command prompt in the Search, right-click on the Command Prompt, and select “Run as administrator”.
Step 2. Type diskpart in the Command Prompt and hit Enter.
Step 3. Hit Enter each time when you type below command lines in DiskPart to quick format hard drive:
list disk
select disk 2
(Replace 2 with your disk number)
list volume
select volume 10
(Replace 10 with the volume number of the device that you want to format)
format fs=ntfs quick
(If you need to format a storage device to FAT32 or other file systems, replace NTFS with FAT32, exFAT, etc.)
Hope this method works :wink:
  1. You can fix internal logical issues on your micro SD card using CHKDSK:
  • Connect the memory card to your PC.Type cmd into your Windows search box.
  • Right-click Command Prompt and select Run as administrator.
  • Input the command below, substituting * with your specific SD card letter (e.g., E:):chkdsk *: /r
  • Hit Enter to start the diagnostic and repair cycle.
  • Reboot your system afterward and attempt the format again.
  1. Run a Malware Scan
    If the repair utility fails, malicious software might be blocking the drive.
  2. Wipe and Rebuild Partitions via Disk Management
    When standard formatting fails, clearing the drive framework entirely can help. Try these steps:
  • Right-click the Start menu (or press Windows + X) and open Disk Management.
  • Locate your SanDisk storage drive and verify it registers as online.
  • Right-click the card’s partition bar and click Delete Volume.
  • Right-click the newly created Unallocated space.
  • Select New Simple Volume and follow the prompts to generate a fresh file system.
Read this blog for other solutions: Windows Was Unable to Complete the Format, How to Fix
