Micro SD Card Pictures
I took some pictures on my camera, and then transferred the microsd card directly to my new Fuze, and it says ‘Unsupported File Format’  or doesn’t show up at all. The Microsd card is sandisk brand, so I thought it would work. What do you have to do in order to get the pictures onto the Fuze?
Unfortunatlly you need to run the pics thru Sansa media converter for them to work on the fuze. The files will still be on your card but you cannot view them on the fuze. I would suggest you leave this card in the camera and then get another one for your fuze. Then use SMC to transfer the files to the fuze from your camera.
What if i ran them through the converter, deleted them off the card, load the pictures that I ran through the converter back on to the card, and put it in the fuze? Would it work?
“Unfortunatlly you need to run the pics thru Sansa media converter for them to work on the fuze.”
That is not true. Regular JPG files will play on the Fuze if they are small. I use the software that came with my Canon digital camera to make copies of my photos that are around 600x450. These play fine on the Fuze. I don’t know what the largest sized image the Fuze will play is.
