Mac Installation
Have tried to download the firmware on my Mac several times.  I get a message saying “This program cannot be run in DOS mode” followed by (?) computer language.  So I haven’t gotten any farther than seeing the “connected” on the Sansa Clip Zip.  Help!  Am a non-tekkie Baby Boomer.  :)
You cannot download and/or install the Firmware Updater. Is this what you’re trying to do?
Download and extract the firmware .zip file (identified in the post by
Manual Firmware Update (Download and Instructions)
Manual Firmware Update (All Regions) - Click here to download
and manually update your player per the instructions found in the firmware post.
Follow this link:
I just bought this sanDisk and am trying to hook it up to my mac. I downloaded firmware, but it won’t install.
how do I hook up san disk to a Mac and use my itunes content? I downloaded firmware but it doesn’t open or install
If you explain exactly what you did, maybe we can determine what is wrong. Did you manually set the player to MSC mode? Did you un-zip the firmware file? Did you place it in the root (top) directory?
