Downloaded the new firmware update. Unzipped it’s: m300a.bin
Stuck that in my root directory and nothing.
Sansa Clip+ won’t recognize it. Using a Mac with Snow Leopard.
For some reason SanDisk isn’t Mac-Friendly, so I have to do this manual style. And no luck. This is really aggravating. I’m firmware upgraded a ton of things before: Cameras, Blu Rays, TVs, etc. They all work. This just isn’t working.
Here’s a photo of my directory. There’s a DID.bin file that I’ve also tried deleting too, perhaps thinking that it only needed 1. But with DID.bin with and without - nothing. Will not recognize it. Will not install it or refresh it or anything. Doesn’t even show it’s there when I use the device.
When I detach the computer with the m300a.bin in the root directory
You shouldn’t be seeing m300a.bin when you unzip…what you need is clppa.bin. Are you sure you’re not trying to load an original Clip firmware onto a Clip+?
Thebmill, you are partially right: Macs are very easy to set up (seemingly–I don’t have one), if you are doing everything the Mac’s way and staying in the universe that it wants to keep you in (and wants to force upon you?). However, when you use the Mac and then stray to the PC (as vs. Apple) world, the Mac can cause problems, which it doesn’t, seemingly, try to resolve–instead, it can push the problems and the need to solve them on the other devices. For example, the case, often. when trying to download files from a Mac to non-Apple devices, such as audio players and cameras, in which case the Mac creates extra files that clog and can stall the devices.
