I did use the ‘reset all’ option under the settings menu. It did not help. No warranty. it was used and $13.00 so returning it would really not be worth it. Thanks
So there isn’t a way to start the player in recovery mode like the c series?
I was hoping I could power up and hold down a button or something.
The internal flash memory is still woking because I can play the files. I’m thinking the firmware is corrupted.
Message Edited by rengobnor on 09-22-2007 06:59 AM
I’m having the same problem with my m260. It’ll play the songs it has just fine, but my computer is unable to recognize it as a disk, so that I can make changes to the content.
I have Win XP Sp2
When connected the unit displays normally at first
first ‘initializing’
then switches to
USB connected
with circle that is half black
and either MTP
or MSC
depending on which way it has been set
after about 2 seconds the unit’s screen changes to the regular play mode display
and the device not recognized comes up on the computer
Thanks
Message Edited by rengobnor on 10-03-2007 02:59 PM
