m230 wont format any tips will help.
hainzinger
hainzinger
How are you trying to format your player? If through My Computer, make sure the player’s in MSC mode.
its in msc mode but i click format it takes about a secont and it says windows cant complete format
I have a windows xp if that helps any
hainzinger
You might try defragment prior to format. I had a similar problem, but it also wouldn’t delete/add files as well. After defrag and deletion of all files, it works like it’s supposed to.
Good luck
How do I defragment my m230?
google is your friend. http://support.microsoft.com/kb/314848
in my m230 when i connect usb it shows the connection in m230 bt nt i n pc wt to do???
