m230 froze
Hey I have a sansa m230 the 512mb one.
I uploaded some music and now it will not go past the initializing stage, it just bounces back and forth and never turns on.
Does anyone know how to rectify this problem?
Any help other than buying a new would be great.
try activating the hold switch, then connecting to the PC.  if it shows up as removable disk under My Computer, your going to have to format the player.
Does the “Sansa” screen on the player say the firmware version. It will say “Sansa” on the screen and a series of numbers above it. Curious to see what version is doing this to you if possible.
