Looking for a quality FM transmitter for Sandisk Clip +
Has anyone found a high quality FM transmitter for my car which is compatible with the Sandisk Clip+? (no input jacks on my CD player-it would just plug into the cigarette lighter plug). Thanks!!!
I also have been looking for one.  Same situration Car Radio has no AUX plug.
So far I have found (2) two that I think might work OK.  Reviews are decent enough.
But would like to know if anyone else has found or is using a better one.
http://www.dealextreme.com/details.dx/sku.14617#open full view
http://www.amazon.com/Griffin-Universal-Transmitter-Charger-Players/dp/B000JV9NL2
Rocky
Hey, I found a great one by accident, the Philips TransCast.  It’s in this thread under Sansa Accessories.
Bob  :smileyvery-happy:
Bob, Thanks for the info. The Philips Trans Cast looks good.Have you tried it out?
I just had to listen through a Belkin FM transmitter for a couple hours…powered by AAA batteries…and it sucked. The lower fidelity was even noticeable on 13-year-old car speakers, and at least half the time I had to hold my hand on the transmitter to boost reception, even though it was already sitting on my leg. It was better than the alternative, which would have been no music at all, though.
I use the transcast fm it will work with any audio device that uses a 3.5mm headphone output it has a good range up to 25 feet also includes a car charger I got it at kaleeko for about $20 with free shipping
