hello, this is my first post here…i would like to use the sansa clip+ in my car
and can only use an fm transmitter/charger device
does anybody have any helpful suggestions please?
thanks in advance, j
hello Tapeworm: you rock! thank you so much for your help… j
I don’t use the clip for this, rather a flash drive. I got an fm transmitter from Meritline, I don’t care for ebay unless nothing else. You might have a noise problem if charging the clip while driving, you would need to test. The transmitters are very inexpensive so you won’t lose much to experiment.
hello,
i have decided on this one:
http://www.satechi.net/index.php/ipad-iphone/soundfly/soundfly-aux
there are a few concerns but the pros outweigh the cons
the website lists a couple of other units at different prices
thanks for your help, j
Looks like a very capable unit but it is a bit pricey. Good luck with it, they area nice thing to have and can be taken from car to car.
