Try re-formatting your Clip. I had some issues with my Clip skipping parts of audio books that were solved by re-formatting then upgrading the firmware. If you do this,you’ll have to replace all your data. Since I use mine only for books, it’s a non issue for me as I remove each book after listening. In fact, I re-format periodically to delete the old book after listening to it.
I’ve listened to books in excess of 50 hours regularly.
Thank you for advice. I’ll try to format my CLip, but it seems to me that it is firmware’s issue - I can’t remember that I had such problems before last firmware update.
Could anyone with same as mine firmware version try the file that I posted as example?
I downloaded the file and I can confirm this behavior on my 2Gb Clip with the V01.01.30F firmware. The Clip seems to recognize it’s length as ~28m:30s, even though it’s actually a bit over 1 hour long. It’s impossible to seek beyond the 28:30 mark, but if left playing it will continue normally. This is probably a bug in the time length calculation. It also happened to me once with a previous firmware (the original .18 IIRC). Something in the file must be confusing the Clip I guess.
the program is designed to convert vbr files to cbr and back but set the output files to vbr to keep the same file size. i have tested your file and it now reports the correct track lengh after proceesing
I first thought it might have something to do with the low bitrates in the original, but the VBRs generated by foobar also have some low bitrates and they work fine… BTW, the file is MPEG v1 layer 3, 44100 Hz, mono.
