loading dvds
I apologize in advance. Am not a techie at all. Have tried to follow the threads to load a dvd onto my fuze and still am lost. Is there an easy step-by-step instruction that I can follow? Also, what is SMC?  Thanks!
Try this: Loading videos and photos to a Sansa player
you will have to rip first the dvd to a format that is compatible with Sansa Media Converter (SMC).  Use the SMC to transfer the file to the player
Go to the Sansa Media Converter board and you will find a lot of information.  Like markqck said, you will need to convert the dvd first, then you can put it on your Fuze using the SMC.  The Sansa Media Converter  board has information on various softwares you can use.
