Listen while it charges?
While I charge my new Clip +, can I still listen to it?  Like the radio?
While charging through the computer? No.
If using an AC-USB charger? Yes.
You also can listen while connected to your computer, if your USB cable is power only (no data) or you plug in your cable lightly so that the data pins do not connect up.  But why would you really want to?  Just listen to the Clip’s music via the computer in that case.
