JPEGS not loading
I’ve had my Sandisk over a year now and it’s started to not load all my jpeg images.
This is completely halting my work flow as a photographer when I organise my images into folders after every shoot.
I have the Sandisk extreme 2TB ssd, are they any fixes for this?
I work on a 2021 MacBook Pro M1
Thanks
Matt
Hi @shoot_alpha ,
After some investigation I found it was quicker just to buy a new SSD. It’s a shame though I had similar issues with a Samsung SSD last year hence why I bough sandisk and now I’m having another issue around the year mark again.
Try connecting the SSD to a different computer to see if the issue persists. If it doesn’t, then there may be a problem with the computer you’re currently using. Also, try updating the firmware on the SSD.
Otherwise, run a file system scan on the SSD. This will check for any errors in the file system and attempt to repair them. Format is also an option to fix the error but your photos may be lost and you will require photo recovery software.
Consider trying a different USB-C cable and port, updating firmware, and checking image file integrity. If the issue persists consider replacing the drive.
Hey @shoot_alpha, have you tried running a file system check on it? Sometimes errors in the file system can cause files to not load properly. Also, if you’ve lost any photos, there are recovery tools that might help retrieve them before formatting the drive. I know a few. Let me know if you need help with that.
