Hello!
To start Sansa:
*2gb
*refurb
*Firmware version: 2.03.33
And my micro sd is 4gb.
I have succesfully used in the past the same micro sd without issues. But one day decided to changed my music so I deleted the music in the MicroSD and now that I have put my music together again I tried the following things:
-Put the MicroSD into my laptop, transfered the music and then put the SD on my fuze, and didn’t work, it did said refresehing media and all that but at the end said NO SONGS.
-Put the SD into my Fuze, connected it to the laptop and try to pass the music with the following results =
*Sync - said changes could not be saved, try again or unplug and plug again and try again (neither worked).
*Right now I can’t remember which is MTP and which MSC, but in the one that recognizes the sansa as just folders like and extra letter of the disk? It shows all the folders, like Music, Audiobooks, etc etc etc but just recognizes the 2gb of the sansa itself and not also the 4 of the SD, so I don’t have the space.
–In the option that recognizes sansa as an mp3 player and you get all the options like sync and browse files etc etc, as sync doesn’t work I try to go to browsing files then it shows the external usd card and the internal memory, there I have 2 issued first my external usd card was showing but as full because it said it had 0mb of capacity and also 0mb free, then I don’t know what I did or why it happened but then it started recognizing the card the whole capacity which actually shows something like 3.66gb but when I tried to transfer things there, and it said I was not allowed to make changes or add things. The latest was that it was not letting me add anything so I format the external usd card while it was still in the sansa with the option it gave me by right clicking and that was it is showing again that it has capacity of 0mb and 0mb free.
When the SD is like that I have noticed my sansa gets slower specially if I try to access System > Info.
Any suggestions please? I really miss my sansa, I was able to use it without a problem before, I don’t know what happened.
I also have format the Sansa, soft reset, restore factory setting… and all the “simple” things without luck.
As well I format my SD outside the sansa, in FAT 32 and it my laptop it does work good and shows and let me store things etc, issue is when I put it inside sansa.
So right now my two issues are: Having my Sansa recognize the sd with the real capacity it has and also letting me add music.
Thank You So Much in Advanced !
Musi =^.^=
UPDATE:
I did an “extensive” format to my MicroSD (unchecked the “quick format” option) in my computer, with no luck, then I decided to add ANY file to the SD and put it inside the Sansa and now Sansa IS recognizing the SD with its full capacity, took the memory out, deleted that file and insert the memory again, and Sansa keeps recognizing the SD “correctly”. Then I connected the sansa in MTP and said I didn’t have permissions to make changes so couldn’t add a single thing. Unplugged, changed USB mode to MSC and connected again, this time it was still recognizing sansa internal memory PLUS external (SD) opened that last one and copied my music folders/files (all mp3 and sansa haven’t created any folders on the sd or anything). Unplugged >refreshing media… Then I went to System > Info and it was still showing internal memory as it should, SD also as it should, with the capacity it has and with only 753mb (which is correct since I put like 3gb in music) but where it shows how many songs or files of other types still says 0 songs ![]()
