Is there anyway to print the list of songs?
I tried using “Print Folder” , and I tried just cut and paste. I caN see the mp3 files but I can’t pint then out.  The only thing I can think of is to print sceen and use irfanview.  Any other suggestions?
Thanks
You can do it with the favorite (and most recommened) utility here, MP3Tag. Open up your entire Music folder in it and then go to File > Export. You can select the format of list (and configuration) you want and print it out.
Thanks for the tip! Thats what I need. MP3Tag generates a CSV file. Cool!
