I have the Sansa Clip 4GB player. I have several folders containing mp3 files under Computer\Sansa Clip 4GB\Internal Memory\Music. e.g.,
Folder A
Folder B
How can I play songs in a particular folder? If I do play all, it plays songs randomly. I have also tried playing album etc. but it doesn’t do what i want. I want to play songs under a particular folder, and I want to be able to repeat or randomize songs under this folder. If someone can help me, thanks a lot.
The Clip does not read nor play by folders/files. It is strictly an ID3 tag-based player.
Only the Clip+ model and the Fuze have this capability. To do want you want, you are going to have to create playlists of the songs, or tracks in those particular folders, then play the playlists.
Also, various users have created software that will create a playlist for each of the folders on your Clip. You could run that and then play the playlists.
Great idea there . . . I forgot about those. This is the exact scenario that inspired this program (and others) to be written in the first place; the lack of folder navigation/playing on the original Clip.
Another case of necessity being the mother of invention.
