I often use my sansa clip+ forrecording , but when I delete the wav. files on the clip with my pc and the file is empty, the sansa clip shows all recording titles in the index althoug the recordings are deleted.
Thanks for any help!
A reset delivers no change. How can I do a “database refresh”?
Could help the deleting of all files an then install the firmware from new?
There’s an MTABLE.SYS file that is the actual database file. Connected in MSC mode you could manually delete this file. When you un-plug from the computer, the player will go through its database refresh but this time instead of just updating it, it would build an entirely new database list. Your deleted files should then be gone.
