A set of speakers with an integrated docking cradle for my Fuze. All the ones Ive found so far are for the e200 or the clip, which are narrower machines, so I assume that the fuze won’t fit into the docking cradle, or if it will, it will requre some filing away of the plastic on the cradle to make it fit.
Can someone point me in the right direction?
Two words: Altec Lansing. Look at the IM413 model here at the Sansa Store . If you check out Altec Lansing’s website, they have a portable version of the unit, battery powered too, with a unique pop-out dock.
The units were engineered with the narrower, symmetrical (centered 30 pin connector) e200 in mind, but many are using these babies with the new Fuze.
Bob :smileyvery-happy:
