Hello to all, i just bought a SanDisk-Sansa Clip+ 4GB* MP3, and well i wanna get a cheap Wall Charger adaptor, which one you guys recommend me that is cheap and good that i can buy online? thanks
Buy any one of the cheap USB/AC adapters out there, and plug this into it.
You can get a Motorola Razr charger(made by Motorola) cheap online. I think some places sell it for around $2-4. Make sure shipping price is low though.
This is the one??
http://www.amazon.com/Motorola-Mini-Wall-Charger-Phones/dp/tech-data/B0009H2M1Y/ref=de_a_smtd
I prefer this style because I have both a Fuze and a Clip (and a Clip+, and other things that can be charged by USB). I’m not endorsing this exact product - I got mine off eBay - but saying I like this style. Use your own cord or find one that comes with a new cord.
how much power output should the wall charger have? I have so many from all my other devices.
my LG phone is: 5.1V 0.7A
My Archos 605: 5.0V 1000mA
and I’ve seen others in stores that are: 500mA
what’s going to minimize charging time, but not fry my Clip+ 4gb?
The more amperage (mA) the faster it will charge. The Clip+ has managing circuitry that will controll how much it draws, so there’s no chance of burning it up.
iS IT POSSIBLE TO CHARGE MY SANSA CLIP PLUS WITH A WALL CHARGER
And will the Clip+ work whilst being charged this way, under the Sansa firmware? If not, perhaps in rockbox?
Yes.
Many thanks tapeworm. Just to be clear: it’s possible under the sansa firmware? When i’ve connected to my PC (i don’t have a charger yet) under 01.02.18F i don’t think i can play files.
What part of “Yes” isn’t clear, the “Y”, the “E” or the “S”? ![]()
When connected to a computer, the player goes into “data” mode and normal operations are suspended so it will not play. When using a wall charger, there is no data connection on the other end so it will play while beiing charged.
Many thanks for the expositions. I was looking to use the clip with my hifi and th-ought it might be useful to have it plugged in to a charger. A suitable docking station would be good - any recommendations?
