how to use a micro SDHC card in a 8GB Clip+
Hi folks, have I got this right ???
In order to play extra music on the clip+…
1         Buy an microSDHC card eg   8GB                   and         an adapter
2          Plug into a PC   (will figure that bit out when I get a card)
3           Format to FAT32
4           Tranfer music to clip+
5            Ensure clip is switched off (probably)
6            Cross fingers, switch on  & listen
much thanks
hal2
2          Plug into a PC   (will figure that bit out when I get a card) Just plug it into player, then player into computer
3           Format to FAT32 Not necessary. New cards come pre-formatted.
5            Ensure clip is switched off (probably) Not necessary.
6            Cross fingers, switch on  & listen. You should be good to go! :smiley:
much thanks
hal2
5            Ensure clip is switched off (probably) Not necessary. The Clip+ will refresh it’s database upon disconnection from your computer.
much thanks
hal2
Excellent – much much thanks !
hal2
