Is there a way to stop the Clip’s radio when I scan for next station (not via the menu, but with a long press on the “rigght arrow” button")?
Thanks!
Thanks!
To stop it from scanning, just pressing either the right or the left button again for about 2 or 3 seconds usually stops it for me. You might go over the channel you’re looking for, the first couple of times. But once you get used to it, you can stop on the exact channel you want
Enjoy
Thanks! that works.
Strange that it needs a long press…wouldn’t have expected such a design.
AR
