How do I make fm radio work .? on my clip?
I guess I can’t figure it out is there step by step instructions?A manuel would be helpful but I can’t seem to download it either
just press the home button then select radio.  you should be able to tune to your favorite station from there.
you can find all the user manuals here or go to kb.sandisk.com and type in UM
I had the same problem and as it turned out, I just needed to press play. If there is a square under the station numbers, that means stop.
