How to run Sansa clip 4g thru car radio speaker system
How can I do this or is it even possible… Thanks
The best way is if your car’s stereo unit has an AUX IN or USB port. Otherwise, you can use an FM transmitter or cassette adaptor; neither one of which work very well. In other words, you will not get the same sound quality and volume as you do with the earphones.
I have the fm transmitter… Thanks,…
