How do you know when battery is fully charged on my Clip & Clip +?
I don’t want to OVERCHARGE
Rick4q
Rick4q
You won’t overcharge: the Clips have an overcharge protection circuit.
But you can check the amount of the charge left by looking at the Clip’s battery icon on the display: if it is full, 2/3rds full, 1/2 full, etc. You can also look under the Info screen (under the settings) to see the amount of battery charge left.
Thanks for the correct information.
This is the reply I received from a SanDisk Tech Rep.
Thanks for emailing SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product.
I understand that you don’t want to over charge the battery of your sansa players. I would like to inform you that when the battery is fully charged it will show you a message “charge complete”.
I knew he was wrong because I have been charging 36 Hours & no “Charge Complete” message yet.
Thanks Rick 4q
Continuously charging for 36 hours? Yeah, there’s no message, just the battery animation stops when it’s charged. Unplug and check Settings> System settings > Info and scroll down to see the % battery charge.
Thanks Rick 4q
1.) The “Support” person needs to go through some more training. There is no (nor never has been) a “Charge Complete” message.
Thanks Rick 4q
1.) The “Support” person obviously needs to go through some more training. There is no (nor never has been) a “Charge Complete” message.
Thanks everyone,
I was wondering the same thing.
The little icon that comes up on the bottom of screen when the sansa clip+ is plugged in to computer says power is "extremly low (0%), and it says the same thng in the Sansa updater window.
I followed your instructions and checked the info screen of the the Sansa unit itself, and it shows 100%.
duh! to Sandisk.
Thanks to all who contributed.
I think WE THE PEOPLE would be lost if we left it up to the manufactuers. We need each other.
Live long and prosper.
danny
