Using a MAC operating system.
32 gig Sandisk wieless flash drive.
Ipad air
When my sandisk wireless flash drive is connected wirelessly, and I go to sandisk.com on my Mac - no files are shown at all. No folders either. The page just says:
SanDisk
SanDisk Connect Wireless Flash Drive
The rest of the page is empty.
I’ve formatted the Flash Drive to Ms Dos(fat). It says on a forum to download a file called wfd1105.df2, and put it onto the flash drive. Then eject the flash drive and it should start to install, in order to re-configure the drive. The file does not run when I eject the drive.
When I use the IPad to access the wireless flash drive, a ppop-up states “Wireless flash. A firmware update is available for your Wirless Flash Drive. Do you want to update now?”.
I click OK, and get the message “Memory card format not supported - The memory card file system is not supported. Reformat to a supported file system”.
Where do I go from here?? Completely at a loss.
