Help! I accidentally deleted videos from my SD card. Is there any way to recover them?
I would like to ask you a headache-inducing question about data recovery.
I had some very important videos on my SD card, but my brother accidentally deleted them a while ago, and I only discovered this recently when I needed to use them…
I’ve already tried scanning with Recuva and PhotoRec . But strangely, these programs only show the files currently on the card ; they can’t find the deleted videos at all.
I’d like to ask everyone, does encountering this situation mean the file is completely lost (overwritten)? Before giving up entirely, I’d like to post this and ask the experts in the community if there are any other more powerful free/paid tools, or other unconventional methods worth trying?
Thank you all in advance! Thank you so much!
@Susie33
( Get Support for Your SSDs and Flash Products | Sandisk )
Try this these.
How much time has passed since your brother accidentally deleted the videos? If anyone continued to record videos, take photos, or write new data to the SD card after they were deleted, the old data would be directly overwritten and can never be recovered.
Additionally, if the card underwent a “low-level format” during this period, or if certain devices (such as some newer smartphones or cameras) performed a zero-fill (similar to a TRIM mechanism) upon deletion, the data would disappear completely.
You can try other more powerful professional recovery software to deeply scan the SD card and check the scan results to see if your important lost video is there. Important: The recovered files must be saved onto your computer’s hard drive and cannot be saved directly back onto the SD card. If the video is extremely important (such as weddings, precious memories, or business footage) and recovery software yields no results, you can send the SD card to a hardware-level data recovery center to have professionals attempt to retrieve the video files. This related blog post might also be helpful to you: How to Recover Videos from SD Card on Your PC and Mac?
The fact that both Recuva and PhotoRec only see the current files isn’t a great sign, but it doesn’t automatically mean the videos are gone forever. It really depends on what happened after they were deleted.
If the card has been used to take more photos or videos since then, there’s a good chance the deleted data has been overwritten. If it hasn’t been used at all, still try a couple of other recovery tools before giving up. I will suggest Stellar Photo Recovery software and make sure to run a deep scan. If possible, create an image of the SD card first and scan the image instead of the card itself.
I’ve seen cases where one program finds files that another completely misses.
If Recuva and PhotoRec only show the existing files, it doesn’t automatically mean the videos are gone forever, but it does make recovery more difficult. First, stop using the SD card completely to avoid any further overwriting. Also, can you confirm whether the videos were deleted normally, or was the card formatted afterward?
I’d also try a deeper scan with other tools, as they sometimes detect file signatures that other tools miss. If the videos are extremely valuable, avoid repeated scans and consider a professional recovery service—the more the card is used, the lower the chances of a successful recovery.
Here’s a video that might help:https://www.youtube.com/watch?v=L4Dn-iBRTEQ
Don’t panic. Recuva and PhotoRec not finding your videos doesn’t mean they’re gone for good. Those tools mostly scan the file system, and if the file entries are damaged or the videos were stored in a tricky location, they can easily miss them.
As long as you haven’t written much new data to this card since the deletion, you still have a good chance.
Step 1: Stop using the card immediately
Take the SD card out of the reader and don’t put any new files on it or format it. Every time you write something new, you risk overwriting the actual video data blocks. Once overwritten, recovery becomes impossible.
Step 2: Try a deeper scan with a more powerful tool
Recuva and PhotoRec rely heavily on the file system’s directory structure. For your case, you need a recovery tool that does raw signature scanning — it looks for file patterns directly in the raw data, ignoring the damaged file system altogether. I recommend 4DDiG, which offers a free trial (2GB recovery limit) so you can scan first and preview your videos before paying.
Here’s what to do:
Insert your SD card into the computer and launch 4DDiG.
Select your SD card, then choose the “deep scan” mode and start scanning.
After the scan finishes, filter the results by video files and use the preview function to check which ones are playable.
Recover those files to your computer’s hard drive, never save them back to the SD card itself.
Step 3: If deep scan still fails, stop DIY attempts
If even a deep signature scan can’t find your videos, the situation is likely more serious, maybe the card’s controller is failing, or the data has been physically overwritten. At this point, if those videos are truly precious, your only real option is to contact a professional data recovery lab. They have specialized equipment to read flash memory chips directly in a cleanroom environment. It’s expensive, but it’s your last shot.
If Recuva and PhotoRec are not finding the deleted videos it does not always mean they were overwritten. As long as the SD card has not been used much since the files were deleted there is still a chance. At this point I would stop using the card and try Stellar Data Recovery since it performs a deeper scan and can sometimes recover files that simpler tools miss. If Stellar cannot find the videos either then they were most likely overwritten or are no longer recoverable.
I had this exact nightmare last year! If Recuva/PhotoRec only scan existing files, the partition index might be corrupted rather than fully overwritten meaning the videos could still be there.
Before giving up, try EaseUS Data Recovery Wizard. Its deep-scan algorithm is much stronger at picking up raw video fragments from damaged indexes where free tools fail. (Pro tip: do NOT record new photos or save anything onto that SD card right now). If EaseUS also comes up empty, look into raw image carving with R-Studio or DMDE as a last resort.
There’s still a possibility of recovering the videos, especially if you stopped using the card immediately after deleting them.
Since you’ve already tried Recuva and PhotoRec, I’d try one other recovery program such as EaseUS Data Recovery Wizard and run a deep scan of the SD card. Different programs can sometimes find different file remnants.
The important thing now is not to record anything new on the card. If the videos are found, recover them to your computer or another storage device, never back onto the SD card.
If nothing useful is found and the videos are irreplaceable, professional data recovery may be worth considering.
