Micro SD File Recovery
Hello Everyone,
I had a recorded video saved on my microSD card. I had just completed cutting/editing the video on my mac using iMovie and I saved it so I thought the transfer was complete. I hit the button to upload the video to youtube and the the upload started. About 30 mins later when the upload was about halfway done I (like an ■■■■■) removed the memory card from the mac because I figured it was already saved on my mac hard drive (it wasnt). After the upload to youtube was complete, the first half of the video was perfect but the second half was completely black screen (beside the text and effects I added). The two video files on my SD card are still there but its 0kb. I tried to recover using Recuva but it didn’t work. Is there any suggestions on how to recover these videos?
I have same problem…
i deleted some video folders (100ANVxxx ) from my SD card ; been trying for hours to recover them (days late) via mac with no success.
i have not written any new data on the SD since.
Hello guys!
You should try data recovery software.  If the SD card is still readable (the chip / hardware not broken) then data recovery software should or may be able to find back the data.  If not via file system references (e.g. remainders of FAT) then the software may at least find files based on their signature during a raw / data carving scan of the entire medium.  The latter gives mixed results, depending on the data and if the files were fragmented on the card or not.  Pictures etc. are usually not a problem.  You can try this software  if you wanna solve your problems: Disc Drill and I’ll be here to provide support if you need it.
I think it is possible to restore deleted files on Micro SD card, there are many ways to do.
A helpful data recovery software  can save much time and get back lost files easily.
After this method, you can restore deleted files on SD card in a simple way.
Do not write new data on it, then try data recovery programs. Except for Recuva, there are many other programs can do video recovery, such as Bitwar data recovery, Disk drill, iCare, etc. Try again. Maybe it will work.
Good luck.
Or you can try TestDisk, which is also completely free. Some commercial data recovery software offers a preview feature, which means you can check if the YouTube video is complete before restoring it. If everything looks fine, you can consider whether to make a purchase. However, most recovery software usually offers a free trial. For just two videos, this should be more than enough.
Since the files on your microSD card are showing as 0KB, it means they were likely not written completely before the card was removed. However, recovery might still be possible. And, since Recuva didn’t work, try a more advanced tool. You can try Stellar Photo Recovery for Mac (which supports video recovery). check out this article for SD card recovery on mac systems.
R-Photo is freeware. It can also clone the card to an image file. You can then work on the clone.
I know it’s been quite a while, but just wanted to chime in! It seems like the video files got corrupted after the interruption, and while Recuva didn’t work, you might want to give the BLR data recovery software a shot.
It specializes in recovering data from various storage devices, including microSD cards, even when files are damaged or show as 0KB. Hopefully, it can pull the files back for you!
Now, stop using the SD card to copy files, since every new write can overwrite the lost video data.
iMovie sometimes keeps temporary render files, so you may be able to find partial video data there.
Check: ~/Movies/iMovie Library/Render Files or ~/Library/Containers/com.apple.iMovieApp/Data/Library/Caches/
If you cannot find the video in iMovie’s cache, try using other robust data recovery tools to perform a deep scan and recover the video file. ( Related: Ultimate Guide to Fix Corrupted SD Card and Recover Data )
The issue is file system corruption from removing the card mid-operation. Since Recuva failed, the directory structure is likely wiped.
Here is the professional recovery workflow:
  1. Stop using the card immediately. Do not format it or run “Check Disk.” cuz writing new data will overwrite your files permanently.
  2. Use a better tool: Skip Recuva. Download DMDE (cheap and effective) or R-Studio (industry standard). These ignore the broken file system and scan for raw video data.
  3. Image first (Critical): Use Win32 Disk Imager to create a bit-for-bit backup of the card to your hard drive. Scan the image file, not the physical card. If the card dies mid-scan, you lose everything.
  4. Scan for MP4/MOV signatures: In the tool settings, make sure it is looking for video file headers.
If the SD card recovery software recovers files that are still corrupt or the card is not detected properly, the damage is physical and requires professional clean-room recovery.
If the files are truly 0KB because the data never physically reached the flash memory (due to a sudden power loss or eject), recovery can be a bit of a long shot. But with professional-grade software like easeus there’s a much better chance of finding the “lost” fragments.easeus is a solid choice here, as it specializes in identifying and repairing media files that other software might ignore
Ouch, that’s a nightmare. We’ve all been there with the premature card pull.
Since the files show 0kb, the directory is likely corrupted. Recuva is okay for basic deletions, but it struggles with raw errors.
Since you’re on a Mac, try easeus data recovery for mac. Its “Deep Scan” looks past the broken 0kb headers to find the actual video data left on the card’s sectors.
Just stop using the card immediately so you don’t overwrite anything, and let the scan run fully. Look in the “Extra Files” folder afterward, as it often reconstructs fragmented videos there (they might just have random names).
