Can I recover these deleted photos on my SD card?
Hi.
I took some new photos before I realized my mistake, but I didn’t entirely fill the card with new photos. Is it possible that the old deleted photos weren’t overwritten? How can I know if they were?
Thank you.
If you stopped using the SD card when you realized the mistake, the deleted photos would not be overwritten. Don’t use it anymore before you find a way to recover these deleted photos.
Of course,you can recover them with the help of data recover program.Mobikin Doctor for Android,which can scan the deleletd photo automatically.And then you can recover your deleted photos on computer.
  If you have got your photos deleted from your SD card then, you can use the internal hard disk space to save the recovered SD card images and video files. 1.     Press on the ‘Recover Photo, Audio, and Video’ option from the home screen.
  1. Afterwards select the problem drive to restore lost data.
  2. Click on to ‘Scan Now’ after selecting your problem
  3. Choose your problem SD card or memory card and click on ‘ Scan Now ’. You will be able to locate successive problem drive status(raw or healthy status) just get a clear view of number of files retrieved.
For more information follow the below link:
How To Recover Deleted Files From SD Card In Easy Way
If you want to recover deleted photos from your memory card then there are several methods available. Few of them are given below, try them out one by one torecover deleted photos from Micro SD card:
1: Change SD Card Drive Letter Name
2: Try CHKDSK Command Prompt
3: Re-Install Card Reader Driver
4: Repair Undetected or Unrecognized SD Card With CMD
5: Use Disk Management to Format SD Card
 6: Format SD Card to NTFS
7: Use Micro SD Card Recovery Tool
Hi Sofia,
Of course, you can recover deleted photos from memory card. Well, this situation is really depressible for all of us, but don’t you need to worry about, I will suggest you an effective way through which you can recover your lost photos. You can try out the below given way:-
Method #1:-Format your memory card using disk management
  • Connect your corrupted memory card to your PC.
  • Now, on your PC, go to the start option and right click on ‘My computer’ and then you need to to select ‘manage’.
  • Then, click on disk management, which is on the left side
  • Right click on memory card and then hit on ‘Format’
  • Just perform a quick format now.
Hopefully, this method can help you to retrieve your lost photos.
It is possible to recover these deleted photos as long as you stop using the SD card and do not write new photos anymore.
Then, I suggest you to use some photo recovery tools to retrieve the deleted photos.
Various recovery tools can do photo recovery from SD card, such as Bitwar, Stellar, Recoverit, etc. Some are paid, and some are free of charge.
Maybe you can try one of them.
If you accidentally delete images from your camera’s memory card, you do not have to worry! Stillbon Photo Recovery Software will help you to restore them through a simple process. This software very simplest to the most professional, you will necessarily find a mounting solution that is suitable for your use.
Just as a reminder, take the card out of the device and set it aside - anything that writes to that card will complicate any chance of recovery. You should have some luck with this software and its free:
There is a possibility that your old photos have already been overwritten. But I’m not 100% sure. The easiest way is to download a free data recovery software and check if it can scan for the lost files. For accuracy, you should try one or more data recovery tools. Do not continue using the SD card, as this will only decrease the chances of successful recovery. If this method doesn’t work, then I recommend hiring a professional to recover lost files for you.
Thank you :hugs:
It’s possible that the old deleted photos on the SD card haven’t been completely overwritten if you didn’t fill the card entirely with new photos. When files are deleted from an SD card, they aren’t immediately erased; instead, their space is marked as available for new data. If the new photos haven’t occupied this space yet, the deleted files might still be recoverable. Try Stellar Photo Recovery software as it will show all your photos (that were overwritten as well) from your memory card.
how do i know if the photos were deleted completely or is it possible still to recover them? For now I am reading how to recover photos from sd card here https://www.cleverfiles.cоm/howto/recover-deleted-photos-sd-card.html and hope it helps somehow. I tried few other things before, but it didn’t help unfortunately
You can check the SD card by yourself on a computer, if you can’t find the photos, then it is lost. But, to answer your second question, Yes, it is completely possible to recover the photos from your SD card.
Photos are often recoverable unless overwritten or the card is severely damaged. Firstly stop using the card and go for a photo recovery software. Stellar Photo Recovery software is the one you are looking for. As I have said before, it will show all your photos (that were overwritten as well) from your memory card.
Unfortunately, there’s no easy way to see which specific files have been overwritten already. The only way to check is to run a recovery tool and see what it can still find. I accidentally deleted the videos from my friend’s wedding, and this SD card recovery guide helped me get back those precious memories. Hope it helps.
TYSM!!! I restored my photos.
Hey @KrisWuuu
Just curious—how did you manage to get your photos back?
Ask ChatGPT
You have a good chance of recovering your deleted photos because you didn’t completely fill the card with new pictures. Use data recovery software (e.g., Recuva, EaseUS, PhotoRec, Disk Drill, or others mentioned) on a computer to scan the card. This software will show you which files are recoverable. You can often preview photos to check their quality before recovering them. You will know if photos were overwritten during the scan: the software will be unable to find them, or they will appear corrupted and fail to preview properly.
