Some people seem to be having this problem with the latest firmware (01.01.15) (I haven’t seen this problem at all on my own Fuze). Did you upgrade your firmware? If so, try downgrading to the previous version of the firmware. If you haven’t upgraded, then try upgrading anyway, maybe it will help (and you can always go back to the previous firmware).
Sansafix, you are my hero! Yes, this solved by problem.
Two questions:
are you absolutly sure, that a new firmware will be released?
Ok, I will use the custom eq as work-a-round. How should I set the custom eq to accent the bass a little bit? (I like punkrock and it sounds best with bass. But the standard eq was fine for me :)
I boost the bass to 6, mid to 0 and treble to 4 (do the other ones so that it is a curve) and it sounds good! I haven’t experienced this issue, maybe because I use CBR instead of VBR, isn’t that what causes the problem?
EDIT: I wasn’t thinking. Maybe I haven’t had this problem because I use the custom EQ?
