I looked through about fifty pages and didn’t find the answer.
I have a 8gb Fuze w/additional 8gb removable card. By mistake I’ve put some of the same songs on both drives. What is the best way to remove these and if I do delete them, will it also mess up any added playlists?
It might mess up your play lists, what I do is, My playt list is on the card, I go to songs, scroll thru and find duplicates, delete the one that is not on the card. If you have 2 on the card, then Im guessin youll have to fix your playlist as well after you remove the duplicates.
Connect it to your computer, bring up 2 seperate My Computer boxes, one for internal, one for exteranal, and scroll down…delete the dupes from one of the drives, and problem solved
Edit: forgot you asked about playlists…pesky things I hardly use. Those you might have to re-do.
Message Edited by Marvin_Martian on 02-23-2009 01:41 AM
Songbird (mozilla’s music player) has a plugin to find duplicates.
Does it work for files already on a player? MediaMonkey will find dupes too, but I never tried using it to find files already on the player…great for cleaning up your music folders though.
